Can I Run a 99 ECU on my 95 GST & Use Tatrix OpenPort 2.0 To Flash?
bo0st
835
24
Jan 26, 2010
Phoenix, Arizona
Quick question guys, can I Run a 99 GST ECU on my 95 GST & use Tatrix OpenPort 2.0 cable with ECUFlash to tune?
If so does anything need to be changed besides the actual ecu, firing order etc
Quick answer : Yes. Myself and other people are doing it. You'll most likely need to add a black top CAS also due to the fact that the black case ecu doesn't play nice with the 2ga cam/crank sensors. If I can find links I will post them up.
You will use CeddyMods in ECUflash as well.
http://www.dsmtuners.com/forums/evo...first-flashed-dsm-ecu-98-99-flashing-faq.html
http://www.dsmtuners.com/forums/electrical-tech/422407-1999-gsx-ecu-1995-tsi-have-no-spark.html
http://www.dsmtuners.com/forums/newbie-forum/424494-i-have-flashable-ecu.html
I already have a 1g turbo CAS on it, will that play nice with the new ECU?
i was running the same thing u just need to plug an aux wire in pin 98 of your ecu i believe it is to flash the ecu.
just make sure you have ceddy mods and evo scan.
i would also recommend you wire your wideband to your rear o2 sensor wire so you can log it in evo scan
