Help w/ Tractrix Openport, ECU Flash, and EasyOBDII
Jon Lane
406
33
May 1, 2004
SW, Florida
Attempted to read my 2G ECU this morning using Tractrix Openport 2.0, EcuFlash 1.44, and EasyObdII. Both connectors are installed, including cable between them. OS is Win7 64 Pro on a Dell laptop and both programs run following what looked like a successful driver installation.
EasyObdII 2.4.8 will not find the ECU. EcuFlash will run a read sequence but will not recognize the results selecting either the Gen2 '96+ or generic definitions. (Car and original ECU are '98.) This suggests that the drivers are correct but the definitions are not identifying properly.
Previously VCDS (Ross-Tech) ran successfully in Win XP on another laptop using a generic OBD-II connector to USB cable, but now nothing appears to synch. That cable will not function in Win 7 with VCDS anymore.
I've never used Tractrix Openport 2.0 or either EcuFlash or EasyObdII, and since neither of the two programs operate, I must be missing something. Any ideas? I'm only trying to read error codes before servicing, and eventually convert to speed density.
