jukematt
- 291
- 40
- Jun 13, 2009
Portland Metro,
Oregon
I'm rebuilding my engine due to spun rod bearings. I'm just wondering, I have the head and pretty much everything on the block (turbo, intake manifold, etc) except the oil pan. When I am turning over the engine manually, I can hear the air escaping out the bottom of the block. We tried doing a compression test and the gauge after two turns went to about 30 psi, then two to three more turns went to about 60 psi. But each time a piston comes around I can hear the air escaping form that cylinder.
Is this normal? Or could I possibly have a problem?
