Camshaft Position Sensor
chargers503
Feb 20, 2013
salem, Oregon
Im having a couple of issue with my 98 Eclipse RS. After it running for a minute at a idle it starts to run rough and pulsate(Rpm's slightly up/down sparaticly), also the engine vibrates at the same time. Past day or so its become sluggigh bewteen 2-3k when accelerating. Ive done some research and have a general idea that it might be the Camshaft Position Sensor. I haven't checked to see if its throwing any codes. If you have any idea on what it might be please let me know. Thanks for reading!
I have something very similar to that.
My idle pulsates up and down. Also often, when driving I will get a quick sputter and I get a P0340 code for the Camshaft Position Sensor.
Right now it doesn't seem to be a major problem, but I'm definitely going to replace it soon.
Check your wiring from the sensor to junction where it splits from the main harness. Sounds like you have intermittent short.
:banghead:
Saturday morning I plan on checking the sensor and connector, giving them a good clean and seeing what needs to be replaced.
I, also, am thinking it is wiring causing the since it's an intermittent problem.
What does your rpm gauge do? It should jump around if its the crank sensor. Idle surge is another thing so specify more clearly up and down idle
I'm not rightly sure how to explain it. I will try to get a video and post it.
It's almost like something is opening the throttle causing the RPMs to rise 250-600.
Sometimes it happens steadily, sometimes it goes up 700-900, and sometimes it idles fine.
Sounds more like your isc is bad or you have a vacuum leak
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 2g NEW OEM FWD Fuel Level Sending Unit
    2G NEW OEM FWD Fuel Level Sending Unit $85 + shipping & paypal fees* NOT the fuel pump hanger...
  • For sale 1g 1GA OEM Corner Lights
    1GA OEM Corner Lights $65 + shipping & paypal fees* all mounting tabs are intact * the...
  • Wanted WTB 1990 AWD manual Talon Transmission or shifter Forks
    I need a 1990 AWD 5 speed manual Transmission. The transmission has all the shifting forks...
    • 90rallytalon
  • For sale 1g 1g dashmat. Black.
    1g dashmat. Black. Overall good condition. Does have a tear where the dogear flap is on the...
