justinhill98gst
- 190
- 0
- Sep 1, 2007
White bEAR laKE,
Minnesota
My set up is ,t3/t4 50 trim,550cc fuel injectos,255 walbro pump,3inch turbo back exhaust,hks ssqv,act 2100,turbonetics manifold, 38mm waste gate. Im going to be buying the brian cower cams this friday, witch one would you guys recommend on this set up?272 or 280? btw this is a dd car. and im upgrading the fuel injectors to 750cc and switching to the link in a month or 2. also what would you guys rate the cams from 1-10 from 10 being the best 1 being the worst.
but it runs and she is quick and took me 1800 miles on a road trip held 26 psi on a e prom ecu(borrowed from a fellow dsmer to see what would happen!
