turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Well, I had a perfect tune on E85 until i changed a few things a few days ago, and now i'm having to richen everything up under boost.
I've had to increase pulsewidth a TON way more than i'd expect for what seems like a minor change. And i'm running out of injector on 1000cc units at around 23 psi when before i could run 30psi at a aricher AFR before i cam to the same IDC
The one thing i did that i can see changing the AFR's is that i advanced the exhaust cam for more top end power (4* and it made a hell of a difference)
The other things is did were
1.) Run a new piece of rubber hose from the AFPR to the return line on the body (same size and ID just a different color *black* to make it blend in)
2.)although my 2nd pump doesn't run i replaced it with a matching 255hp for when i do decide to run duals again. Instead of just being unplugged like the previous pump (regular 255) The power wire is fed to it but the ground is dissconnected, and i tested to make sure it couldn't ground it's self externally and run and it cannot. there for it shouldn't be drawing any juice from the running pump ( am i right on that? I'm no electronic engineer)
I"m hoping to figure this out without undoing everything i've done over the last few days, the return line shouldn't matter, the power wire i'm iffy about and the cam timing i have no clue on it's effect on actual air intake changes.. any help would be apreciated..well, besides questioning the obvious BLT, wire connections etc.. since i've double checked everything and solder every wire joint, all should be well.
The only othe rthing i can think of is that maybe my fuellab filter is getting dirty, but i do have the SS mesh one, so i wonder if i can clean it fairly easily?? Anyone ever do that?
