bypass the intercooler?
AWD Eagle
273
Nov 11, 2003
Wichita, Kansas
My car is stock right now except for the free mods. I am wondering if it would run faster if I replaced the intercooler with some pipe when it is only around 35 degrees outside or below. Would the cold air cool the pipes enough?
Thanks
You'll go faster with the intercooler. Mitsubishi doesn't like making parts that don't have functions. It's there for a reason.
Thanks
No, you will get more power. You will get less with NO way to cool down the air.
honestly i dont see y you would wanna bypass it :confused: if its 35 deg out side its going to run alot cooler as is.. the intercooler isnt restricting it any esp if its a front mount and if not would the power diff be worth the trouble ?? imo prlly not
Yeah your not gonna see enough difference to warrent taking off and replacing the intercooler and all piping everytime the temp changes. Just keep it on there and dont worry about it - but a set of hard pipes would help if you are worried about that.
Thanks
No, that would hurt you alot. Think about it, regarless of outside temperature, your block is still heating up alot, along with your turbo. Compressing the air increase the temperature of it dramaticly. They air going into your engine is going at a very fast rate. No intercooler=bad
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
