kenamond
DSM Wiseman
- 3,225
- 68
- Feb 15, 2006
Los Alamos,
New Mexico
While I was doing all of my mods I decided to fix the annoying valve cover leak.
I had everything torqued down to spec except the last bolt (next to the #1 spark plug). I was torqueing down this last bolt and heard a "CRACK" and saw that the cover had broken. After cussing up a storm, I decided to continue torqueing it down with the intention of just JB welding the crack. So then it cracks again, and a whole piece of metal came loose (the metal surrounding the bolt hole came off in 2 pieces). After cussing up another storm, I headed to my computer and ordered a new 1G valve cover from slowboy.
I suspect that the #1 spark plug hole gasket shifted out of its socket when I placed the cover on the head. I had put 2 dots of RTV on either side of the spark plug hole to hold it in place, but I didn't put any under the part where the bolt passes through, so maybe that part shifted.
Any suggestions on a sure fire way to get the brand new one on without trashing another $270 (and throwing a torque wrench across the garage)? I could put RTV under the whole gasket set, but I don't trust that that will hold it in place, but I don't think I can let the RTV set up when it's not properly smashed between the cover and head at the proper torque specs.
) Serves me right
