Broke off a chunk of my transmission
bpk1337
118
6
Oct 28, 2008
Phoenix, Arizona
Just finished rebuilding my transmission, and the chunk circled in red broke off. Was wondering how important this bolt hole is. Has anyone stripped this hole, and run their car? Took it to a local welder but he recommended that I completely disassemble everything, and bring back just the bell housing case, because the heat up might damage the parts inside.
This is what I would do in this situation: bolt the tcase to the transmission, and bolt the broken part on as well, after getting it lined up as best as possible. Next, take a side grinder along the crack on the side opposite the t case mating side to create a valley, then have him weld it- slowly, by doing .5" at a time, letting it cool a bit, then going further. once that side is done, unbolt the t case, remove it, and grind the crack on that side and weld. This way, its lined up well, and the Tcase bolted on during welding on the one side will serve to not only keep the parts lined up, but also serve as additional heat sink. Being in that spot, you shouldnt hurt anything welding it, exept for the axle seal, and even then it should be fine.
Thanks for the advice Kchaazz! Beats having to tear apart the tranny again. :D Now to find someone willing to do the work. Probably a good thing the first guy didn't take the job since I didn't have the transfercase with me.
