Breaking up bad really need help i dont know why im studering around 5k Rpms
yeti-gvr4
422
Dec 23, 2010
san diego, California
Here is a log i just made please any help is appreciated can you even tell Im breaking up in the log....
Also i don't have a source of boost control my WG does not actuate enough and lets me creep, I'm preety sure the reason is me creeping to 20 psi + and not being calibrated..
I'm going to put my other WG on and 0 the airflow settings.
I'm just confused because the car never studdered like this until a few days ago.
That log was Hidious.
We need a 3rd gear pull from 3,000 rpms WOT to redline. And then we can help with your issues.
sorry heres a 3rd gear pull from about 2500rpms to as close to redline as i could make it the car breaks up and falls on its face after 5k and gets worse
please any advice is appreciated could this be a fuel problem because of the e85 i just started using it on NOV,4 and have gone threw a few tanks...
What psi are you actually running? It's showing 32-34 psi, If this is incorrect, we need to dial in your maf comp a bit. Because right now it looks all kinds of wacked.
also It's showing that you are at 98% injector duty cycle, That is way to high and can cause your issues. Lower your boost 5 psi and see if that helps.
Checking your fuel filter is a must, that crap is nasty and makes a mess.
What brand and type of plugs are you running?
Im at 98% duty cycle holy shit!!
I am running the bpr`6s i think NGK,
Im going to check the fuel filter and im running an infinite amount of boost since im creeping im running out of fuel because i creep so high that my 1000cc on e85 gets used up
im going to throw my stock wga because that only creeps to 16psi
this is a new log with the other wga attached and i don't studder as bad until the end but i don't know should i run the maf comp on this log...
also im running a 2g maf
Ok so here's a new log after i did a BLT
Im still stumbling around 6k but a lot better it feels like
should i run MAF comp on this log?
You could tweak yor maf comp a bit so that the afr/est matches your Lc1 gauge at WOT.
I don't think thats your issue.
I'd like to compliment your beutiful timing. :thumb:
What turbo are you running?
You could possibly be having spark blow out for a number of reasons.
The easiest way I found to test this, is to drop the plug gap to half of what it is now. If your problem goes away slowly open the gap .01 at a time and record the data so in the future you have the correct gap and heat range for your car's setup.
Your injectors are now at 75% so you still have more room to grow.
In this log your airflow is awsome. and Your injector duty is really high, but I see at WOT your running 9:0:1 AFR. so you can pull fuel out and still run the 32 psi. Without maxing your injectors out.
