Ill-EagleTSi
- 111
- 0
- Oct 17, 2008
Louisville,
Kentucky
Ok I need help figuring out if my head gasket did NOT seal up good.
I rebuilt a 6 bolt engine with all new stock internals, I had the Head milled flat. I also cleaned the block surface really good with some 400 Grit Wet sand Paper and a flat block.
I Used some Bullshit MLS gasket that I got off ebay cause I thought it would be ok...It was called a KABUKI Gasket kit hahahahaha WTF?!?!
So it was a 3 layer MLS gasket that was riveted together. I Sprayed it with Copper spray on both sides. Then I installed it with ARP head studs, Torqued to 95 Ft lbs in the proper sequence and in stages 10, 30, 60, 95.
After 50 miles I re-torqued the head studs.
Now the problem I have is the car is losing coolant...I don't see a leak on the outside anywhere.
And My coolant bottle overflows if I got WOT while the car is hot.
So What I have done was Change the coolant Cap to A stronger one that is 16 psi instead of 13
And I also Removed my Thermostat. I know I shouldn't do that but the car was over heating so I had to yank the t-stat to keep it cool. Now it doesn't overheat. But I still lose coolant and I don't know where its going.
I have searched for like a week and I am thinking its my headgasket cause its pushing coolant out of the over flow...but WHY would my headgasket not seal if I did everything right?
Is it cause I used 400 grit wet sand paper on the block surface? I made sure I used a flat steel block on the sand paper to keep it flat.
What can I do to confirm if the HG is bad or not sealing without tearing the whole engine back apart?
If I do have to get a new HG...what kind should I get? a OEM Composite?
) on a built head (272's, 1mm valves, full port work etc) on a OE rebuilt bottom end.
