2G Brand new clutch slipping at anything past 3k rpm
Dihtung Glava
174
217
May 16, 2022
Kranj, Europe
I have no idea what I could have messed up here, so after 2 days of trying not to pull the trans again, I'm asking the council. I put a new clutch between my 1g engine and 2g trans (I'm pretty sure the generations are irrelevant tho) and the engagement is absolutely horrible.
It feels OK when the car is off and I'm pretty sure it disengages fully as well, but when I release the pedal, the bite only happens at the very top, almost at the last half inch of pedal travel. When driving, the awful bite point is bad enough, but the clutch also entirely slips at anything past 3k rpm.
I still have about a half inch of threads left on the bolt that limits pedal travel but I feel like the problem has to be somewhere else because there's no way the clutch should only start biting that high.
I've bled the system from the master and the slave cylinder 3 times - the first 2 times I left the adjustment on the master as it was on the old clutch, and for the third time I twisted the rod all the way out.
I can compress the slave by hand and it returns to original position without problems.
Am I doing something wrong or could my new clutch be defective?
I kept the same flywheel.
The clutch was old and worn but I didn't want to go full send on an ACT clutch just yet, so I just got a "OEM" replacement while I had the engine and trans apart. It was 50€ so I was happy but now I feel like I might regret it😬
Was everything clean? Did you machine the flywheel? Have you adjusted the master?
I cleaned everything with brake cleaner before installing. I did not machine the flywheel. I have adjusted the master, I'm just not sure it's helping.
Maybe it's me but that pressure plate doesn't look like it's even the correct one for the car. It looks much deeper than it should be.
It is deeper than the standard eclipse pressure plate, the 6-bolt I am working on came from a galant, so it has a flat flywheel, without the extruded bosses for the flywheel bolts. The pressure plate is just as deep as the one that was there before.
You can compress the slave by hand after you do adjustment but try pumping the clutch pedal a few times, then see if you can still compress the slave.
Will do.
Can you reach down and push the slave cylinder in by hand?
I can. It compresses and returns normally.
Is it a non turbo 4G63 clutch on a turbo 4G63? I know you euro guys had n/t 4G63 2Gs instead of the 420a we got.
Yes. But I don't think the turbo is the issue if that's what you're getting at - the old clutch lasted years even with the added power.
To the US folks: This is a non-turbo 6 bolt which uses a non-stepped, entirely flat flywheel and a corresponding flat pressure plate. Off the top of my head I cannot recall the clutch disc thickness but I believe it should also be the same as the turbo discs, about 8mm new thickness.
To my buddy Headgasket, keep in mind a clutch can wear unevenly and wear the flywheel unevenly too. So much so that, unsurfaced, a new friction disc wont make full contact and will lead to the issues you're having. Flat flywheels also require machining IF they are found to be concaved or too worn. It's very hard to see with the naked eye, sometimes you can sort of feel it by running your finder over it.
What brand is the new clutch kit? It doesn't look like an Exedy since I'm not seeing any marks. If it's a Luk or Valeo you might as well toss it in the bin. Based on your photo, I would say the pressure plate fingers (diaphragm) are looking a bit too flat. As a new disc wears, those fingers go even flatter, which is when the hydraulic clutch system self adjusts and applies more travel on the clutch bearing. A good sign of a decent clutch setup is when those PP fingers are pointing ever so slightly outward. It may look insignificant, but it can make all the difference between full engagement/disengagement. This is why people have been saying, have the end of the clutch fork (the end sticking out of the bellhousing) to be pointing ever so slightly TOWARDS the clutch slave cylinder.
At this point I can recommend two things: First, redo the clutch master adjustment *by the book*, watch Jack's Transmission video or write to me on Facebook I can explain it in full detail to you. After you get that done and you can push the slave back with your fingers (and you haven't blocked off the pressure relief valve), test drive the car. If the issue persists, dismount the slave cylinder from the two bolts, remove the rod and insert something like a nut or something strong to act as a makeshift spacer to give it a few more milimeters of total length. THIS IS ONLY TO TEST, but if you regain full clutch operation and no slippage, then the issue is in your clutch travel and improper friction disc thickness.
Well well well if it ain't Stefan!
Bro you have been helping me fix this car for like 2 years and I'm still not done somehow, that's crazy😂
Ok yeah, I guess I shouldn't have just left the flywheel as it was. New clutch is not Exedy, It's Mapco which is ... not much better than Valeo or LuK.
Thanks for the tips, I'll try everything and post again when I fix this.
Ok, I've adjusted the master cylinder as per the Jackstransmissions' youtube video. I don't have a switch at the top of my clutch pedal travel like he and many of you do, there's just a bolt and a lock-nut, so I backed those all the way out - so the pedal had the maximum travel available. Then I did everything exactly as he did. The clutch does start to engage about a quarter inch sooner now, but that's entirely from backing the bolt and lock-nut the rest of the way out of the pedal assembly and it's still waaay too close to the end of pedal travel. The bottom half of the clutch pedal travel is not doing anything.
Kryndon, I fail to see how adding a spacer into the slave cylinder would help the situation, as I need the clutch to bite sooner, so if anything, I need a shorter slave piston, not a longer one. I did remove it just to see what I could do with the clutch fork by hand though, and It seems that when I touch the bearing to the pressure plate, the fork doesn't point towards the slave, its more neutral if anything:
And this is the fork with the piston in place:
it looks about the same to me...
You are likely correct in your assessment that the pressure plate fingers are too flat, because I feel like the bearing should be reaching them way sooner. So now I believe I've either installed a clutch kit that doesn't work with this transmission or I used too much grease on the fork and input shaft to where it's been flung onto the clutch surfaces and they don't engage as well as they should.
Either way it's looking like I'm gonna have to pull the transmission again to see.
If the slave cylinder piston(or rod) is theoretically longer, it will mean that you need less overall travel of the mechanism to get full disengagement. So if the issue was with not enough travel, that would have solved it to some degree, but it may also start preloading the bearing onto the plate fingers. Although on some cars, the TOB is always in contact with the fingers and always spinning, thus getting worn out sooner.
The position you have right now looks fairly okay, and your Paint diagram also looks correct. Your worry about excess grease being flung out is a very possible scenario which I've seen happen before. You only really need a slight dab around the splines. Some people don't even run any grease at all just to eliminate this potentially happening.
I think you should pull the trans out, measure the total thicknesses of your old + your new friction disk and also measure the heights between the mounting surface to the friction surface on both pressure plates, and report back. It's possible your new PP even though it's for a 4G63 N/A, could ever so slightly have different specs and needing a different disc. I really can't think of anything else, considering your clutch worked prior to all this.
Well yeah, a longer rod would provide more disengagement, I agree. But I need engagement not disengagement. The bearing could very well be preloading the PP already. I can't imagine how a longer rod would make this better, only worse.
That said, you (and everyone else) were most likely correct in assuming the old flywheel is the problem. And I was also likely correct in my greasy clutch hypothesis. I finally pulled the trans and I saw this:
I write "likely" because we won't know for sure untill I have the the trans back on, but these two pictures alone look bad enough to belive we found the problem.
I was an idiot and I just assumed the flywheel was good AND I put too much grease on the splines. Flywheel is at the shop as we speak and I'm deep cleaning the clutch plate just in case, I'll update this when I have the car back together. Thanks.
Yeh I'm stupid, I was thinking of the opposite problem about the clutch rod. You're correct!
Also yeah the flywheel don't look good at all, that's probably a good 0.2-0.3mm convex there. It looks like the grease almost reached the contact surfaces, but you might be lucky. Take a can of brake cleaner and spray the friction disc on both sides liberally then let it out to dry fully. This should take care of any residual greases on it.
Hopefully this will fix your problems this time. Oh and just a reminder even if you are doing it right, always torque the PP to the flywheel in star pattern in stages, as well as the FW bolts to the crankshaft!
F*ck boys, not the update I was hoping to make.
I got the flywheel ground (and later cut to get the tempered spots out), I cleaned the clutch disc and pressure plate, I even replaced the fork and got a new throw out bearing. And I cleaned the lube off of the driven shaft. An entire afternoon of trying to wrestle the transmission in later and absolutely nothing changed with the clutch pedal or engagement.
I guess the clutch simply can't handle a rebuilt 4G63T with no balance shafts. I'm assuming it's making a little over 210hp and I guess that's just too far over the 144hp the galant clutch is rated for.
At least here's some data I collected for my boy @Kryndon:
- old PP mounting surface to friction disk: 4.6 mm
- worn clutch disk thickness: 6.7 mm
- new PP mounting surface to friction disk: 5 mm
- new clutch disk thicknes: 8.7 mm
- I also found the angle of the installed pressure plate fingers is completely dependant on the thickness of the clutch disk that the plate holds down. I did some mixing and matching and I found the worn disk had the fingers of both pressure plates sticking out slightly when I bolted it on. The new, thicker clutch disk had them go flat on both the old and the new pressure plate.
That's so, unfortunate to hear, I know how much of a pain pulling the transmission is all the time! Maybe it really is down to a weak pressure plate. After all the torque difference between the 2G turbo and N/A is about 46% which is not a small number, 180 Nm vs 290 Nm. Might be worth checking the German Kleinanzeigen ebay and see if anybody has a clutch kit and a 6 bolt turbo flywheel for sale. I can't think of what else it could be.
Not surprised if it’s the clutch. And trust me if anyone knows how much of a pain it is to constantly pull a trans, it’s me. In the past few months I’ve had to pull my trans like four times. Lol.
At least I'm getting some practice in. 🥲 Do you know if anyone makes performance clutches for n/a galants? I really wanna see if I can keep the machined flat-faced flywheel, I would hate having to set up the step height on a used eclipse flywheel😅
if its a brand new clutch also you really shouldnt be putting it past 3,000rpm until after the clutch is broken in, you could " glaze " it and have the clutch slip entirely even if you set it all up properly
Do you think there's any chance that if broken in properly, it's gonna start holding?
Yeah It sucks, but family and friends have been a big help for me - everyone wants to see this thing drive after 10 months of work. Why are you pulling your trans so much?
Clutch issues. It’s how I figured yours was a potential culprit.
Eventually got it to disengage fully and now it shifts and holds great. But boy was it a struggle for awhile.
Nobody makes a performance clutch for that N/A motor. The issue is the fact that the flywheel is flat and not stepped. In fact, I Don't even know why in god's name they ever decided to use a stepped flywheel for the turbo or even the N/A 7 bolt 4G63s. Skylines for example all have entirely flat flywheels. Easy to machine and nothing more to it.
The factory step height range for a stepped 4G63 flywheel is 0.608-0.610" (15.44-15.49mm). When you machine those, the machinist needs to take off the same amount from the main surface and the 6 steps while retaining the optimal height. When a shop machined mine, they f***ed it and it had a much shorter height, around 15mm which was way under spec. The clutch held amazing but it prematurely failed only after ~25000 km and some launches. I guess you COULD go and have 6 spacers with exact height made and run them with a turbo pressure plate and disc, but it's gonna be risky. Not to mention it probably wont be perfectly balanced, and stuff might start coming loose with enough beating and time.
edit: typo in the step height
