1G Brake hard line replacement?
if you mean stainless steal SS brake lines then yes its a pretty common upgrade. not hard to do with a buddy or you can read these if you don't have any car friends to help...
-http://www.dsmtuners.com/forums/articles-suspension-brakes/100353-brake-bleeding-one-person-bleeding.html
-http://www.dsmtuners.com/forums/articles-suspension-brakes/269366-how-use-powerbleeder.html
your car being a '92 didn't come with the bigger dual piston calipers either so doing the bigger brake upgrade will benefit you more than just SS brake lines. its a "while your at it" kind of modification, since your already changing the lines why not upgrade calipers? :D
heres the article on the brake upgrade
-http://www.dsmtuners.com/forums/articles-suspension-brakes/287042-93-dual-piston-big-brakes-1g.html
RRE sells all the parts to do it too
-RRE's Eclipse Brake Upgrades
if you decide to just upgrade the lines its a easy install.
:dsm:
Your 2 options on that are going to be the dealer, if they still carry them, and used. Why are they needing replaced? If there is a hole of something I would recommend using a compression fitting and replacing the section of line needed. You can however just get straight line from NAPA or anywhere in 5ft sections and bend your own. This is hard to do and I don't recommend it though.
