BOV questions?
aceofriches
100
Aug 17, 2007
Spokane, Washington
I have a 90 GSX... running 14 PSI and exhaust.... I want a louder BOV but dont have that much $$ right now... Any suggestions?? can I pull one off another car at the junkyard? open the stock one up?
I would just keep the stock one for now. The 1g is a good bov. If you're tight on money you could try to make a metal recirculation tube which might make it a little bit louder. Or save up for a MAFT set up so you can properly vent.
Do you have an intake pipe? If you don't, get one of thoes and that should make the sound louder.
O myWTF ... Well if your on a budget, look for a used one. Most of the aftermarket Bov's have different sounds. Example: Greddy-type s, is a louder higher whistle, while the HKS SSQV is more of a flutter. Just go on youtube and listen to different ones.
BTW the search button is your friend! :thumb:
Please search before posting new threads, this topic has been beaten to death thousands of times.
