2G GReddy Profec boost controller install?
Bandit___01
49
8
Apr 6, 2022
Murphysboro, Illinois
So I'm installing my new turbo soon (68hta v3 from forced performance, with the wastegate off the O2 housing), I'm currently removing everything I need to remove to get them out of the way so I can get to the old turbo, and I'm curious.
Because I'm obviously deleting the BCS restrictor, can I plug my boost controller into the hole the BCS restrictor plugs into on my intake? Or does it need to be somewhere else? It's an electronic boost controller and to be more specific it's a GReddy Profec.
I kind of understand what youre asking,
Your boost controller goes from the boost line source on the cold side piping to the wastegate actuator.
You will need to cap the vacuum port on the intake
Ok, so cap the intake vacuum line port, got it.
However you just lost me at cold side piping to the wastegate actuator. I'm gonna be running a TiAL and it's going to hooked into the ic pipe for vacuum, would that be what I tee the boost controller into?
If that's what you referring to then I apologize for the confusion, it's late here and I'm tired 🤣
I can’t speak on specifics of the GReddy Profec as I’ve never used one.
Unless your profile isn’t up to date installing the 68hta v3 and Profec with no means of tuning the car is pretty much pointless. With ECMlink or ECUflash or any of the standalones out there the boost can be controlled with the ECU using the same type of solenoid electronic controller’s like the GReddy Profec and A'PEXi AVCR use (I believe they utilize the Mac solenoid). In situations where you’re using the ECU to control boost the solenoid does use the cars factory wiring if desired and all your boost settings are controlled via your laptop, plus it gives you the option of things like boost by gear these external controllers sometimes offered but never executed well.
I’m not usually one to say this, but my advice is sell the Profec to some Nissan guy on eBay for $250+, buy a Mac solenoid for $45, and let the ECU control it if you’re set on electronic boost control assuming you’ve obtained something of the sort being you’re installing the 68hta. Much simpler to install, much simpler to use, and gives you overall much better control.
I know your question was in regards to the GReddy Profec hence why I hate giving that answer, but being your new to it that will give you much less headache in the long run.
I have ECMLink v3 for tuning and it's currently installed
I haven't updated my cars profile yet as I've been busy pulling parts that I'm replacing
I was going to use the Profec to up or lower my boost on the fly if or when I need to, I wasn't planning to use the ECU to control boost
I was going to use the profec to up or lower my boost on the fly if or when I need to, I wasn't planning to use the ECU to control boost
As long as you’ve done your research and you know that’s what you want there’s no harm in that. For some making changes on the fly with a laptop is no big deal, which really it’s not, but I’m with you there it’s nice to click a button and be done opposed to carrying around a lap top at all times, getting it out and booting it up, etc.
When I was still on a “big turbo” I considered the AEM tru boost for this reason as ECMLink’s flex fuel capabilities don’t include changing boost per ethanol content, would’ve made it so a click of a button I would’ve been on my “pump gas boost setting”, though I passed as the cost of the Tru boost by itself with the price ECMLink was bringing used I could simply sell ECMLink and buy an ECU that has that capability built in for the difference the AEM tru boost costs. I’ve only ever played with the A'PEXi AVCR and it’s a royal pain in the ass, while I’ve never messed with a GReddy Profec I’ve heard the same in regards to it so that’s the only reason I made that suggestion, but again it seems you’ve done your research and something along the lines of the GReddy might better fit what you’re trying to do
I can't say I've ever come across a situation where I needed to turn the boost up or down on the fly. Make your life easier and just go with an Ingersol-Rand solenoid.
That's why I have a "Scramble" button on my steering wheel, hooked up to a Mac valve. I have never had to use mine either but it is either wastegate boost or ALL OF THE BOOST! :cool:
If you google "boost controller diagram" you will see a better description of what im talking about
Basically they wastegate needs to receive a certain psi before it opens the wastegate to reduce boost pressure.
So basically what I gathered from searching that, it can be any vacuum point before the throttle body.
The only one I will have is the point where my wastegate is hooked up to my j-pipe right off the turbo, so I'm guessing that would be an ideal spot to tap in, which was what I had originally thought you meant LOL
so basically what I gathered from searching that, it can be any vacuum point before the throttle body
the only one I will have is the point where my wastegate is hooked up to my j-pipe right off the turbo, so I'm guessing that would be an ideal spot to tap in, which was what I had originally thought you meant LOL
It can be before or after the throttle body. The boost line from the intake manifold to the blow off valve equalizes the pressures before and after the throttle body closes
Usually for the sensors with wiring it is much easier to have them at the back of the engine bay at the fuel pressure regulator so you can run just a single vacuum hose across the engine bay to the wastegate.
If you put the solenoid up by the turbo you would have to run a bunch of wires from the battery to the front of the engine bay, then run wires from the solenoid to the back of the motor and back into the passengers compartment
Hey everyone,
I was wondering if I could use the greddy profec boost control solenoid without the controller? Since I think they just use a Mac valve, I tried splicing mine into the OEM harness but when I turn my car on the solenoid keeps clicking.
I am trying to figure out if there is a different problem or if it just that I cannot use the BCS without the controller.
By the way, this video was taken before knowing what it was and I am still trying to figure out some other things with the car.
How have you set up ECMLink for the solenoid? As described @ https://www.ecmtuning.com/wiki/boostcontrol the signal to the solenoid is a 17hz PWM pulse train that can range from always closed to always open and inbetween it's going to activate the solenoid every 0.6 seconds for a variable length of time based on the duty cycle.
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
