1G Anyone know how to use a GReddy Profec-B spec 2? (Boost controller)
SnowmanFD
142
8
Dec 11, 2021
North Seattle, Washington
My car came with a GReddy Profec-B spec 2 and I'm just trying to figure out how to use it. I want to put the boost back to stock or relatively stock (car has a 16g) until i get my timing done.
P.S. I didn't know if this should go in the engine mods, turbo, or tuning but i decided on tuning
And one other thing in the second photo there's a cut out near the shift boost with a bunch of crud in it (its clean now) what is it used for? I cant find a use LOL
You can turn off the unit by pressing the "select" button for more than 2 seconds. If everything is installed properly, the boost pressure would be the stock. (Gate pressure)
Please refer the manual below.
Ok awsome any idea what the other thing is for?
On the manual cars it was a small coin tray. Back in the day when these cars were new it could hold enough to pay a toll but not anymore.
I was thinking the same thing, looked like a coin tray. As far as the profec B.. they are honestly kind of a pain to dial in. I have used one for almost 7 years now and I remember it took lots of pulls to set up the gain, target boost etc but once it is dialed it its amazing switching between hi and low boost. HINT: I spent some time at first thinking I had a bad solenoid once because of boost spike etc and turns out I had a boost leak. So IMO first thing you should do is do a boost leak THEN set up the controller.
I thought about that first but at the same moment I thought that the OP wouldn't ask if it was just a coin tray.
On the autos that's where the normal/econ switch goes as you noted and they needed something to fill the hole on the manual cars so, coin tray...
All it was really good for was rattling,
Yeah I was reading too much into what the OP asked. Thought he was seeing some wires come from that.
Honestly right now i just want the boost turned down so my car doesn't blow up then just using it as an additional boost gauge once i get a tune.
Maybe i could try and get a switch or something 3d printed to replace the coin holder
