Block surface rust
No, you will want to keep the 6 bolt squirters. they are feed from the primary oil galley, and not from the main bearings.
I was supposed to call you, my bad man, but thanks for the info.
Here's a pic of the 6 bolt, I went a different route man.
Also I have to get new main caps, and girdle. Was going with jay racing caps and kiggly girdle, do you know where I can get new squirters from?
You know you will spend about $200 to get the replacement caps line bored to fit the block?
I hope they gave you the block.
Many Supporting vendors sell the banjo check valves ($25 ea) The bodies are another ($20 ea)
Just how much HP are you going for?
You know you will spend about $200 to get the replacement caps line bored to fit the block? I hope they gave you the block. Many Supporting vendors sell the banjo check valves ($25 ea) The bodies are another ($20 ea) Just how much HP are you going for?
Yeah I'm aware. And no I got it for 50 bucks. I'm shooting to match or even beat nick and his awd spyder, and he's pushing 650, so I know I have a lot of work to do.
Pic of the 3 heads and 2 blocks.
You can also see that there is little to no more oxidation on my 7 bolt which originally started this thread.
