Blew my B16g, what are my options?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
Kind of happy that I finally blew this thing due to the problems I have had since I got the car with boost fade and blowing blue smoke at WOT. (Seized compressor wheel)
If I want to stick with my FIC 650s on pump gas and continue to run 20-25 lbs I'd like to know what my options are.
I'd also like to know what my options are if I was to go with bigger injectors and take out the presently used Walbro 190lph and put in the Walbro255 I have just laying around.
I have never really taken a look at turbos since I started my DSM/GVR4 days many years ago because I have never had one blow.
I want to keep the price down in my case but want to know what my options are from a few different angles.
Thank you
You should look in to getting it rebuilt or buying another one. If on a budget you could pick up a 14b on the cheap and use the 7cm 16g hotside from your blown turbo. That setup should be able to put you back to a power level similar to where you were.
i'm in the same boat, and have been searching for a good used one or new one for about a week now. if your hot side is cracked your looking about $500.00 to $600.00 for a new one, used about $200.00 and thats for the hot side only. the cheapest new "evo3" MHI big 16g (not an ebay unit) is from extremePSI.com and there about $899.00 with a 2-4 week wait. good luck
HA, if your seeing blue smoke out the exhaust, u got more problems than a blown turbo. Blue smoke is usually an indication of fried piston rings.
BTW, 16g rebuild kits are like $50-$60 bucks on Ebay, and dont let anyone tell you they suck, i just rebuilt a 16g and T25 on a couple friends' cars with ebay kits a few weeks ago, they run wonderfully.
I would get it rebuilt, but realistically, before choosing your next turbo, what are your goals? Daily suby destroyer? Fun betty? Or big burtha drag monster? I would personally stick with the 16g or go to a 20g for a daily driver, fun turbo's.
Kind of a mix...suby destroyer (one of my other cars is a Forester XT) but love using it in bad weather on dedicated snow rims/tires when my other cars would be left stranded. I am getting tired of them STI's hmmm. It's not my daily but when I do drive it, it does make a 130 mile round trip commute to work. Torn between the 16g and 20g but I am going to bet that the 190 Walbro and 650s won't cut it for the 20g.
If you were going to start from scratch, this is the direction I'd go.
14b chra < $75 or so used
new 7cm exhaust housing - $150 from hahns
Rebuild kit - $100 give or take
20 wheel and compressor housing via ebay - $170
Universal 3" Anti-surge Compressor Housing + Wheel 20G | eBay
You can save a lot by scouring ebay for used housings. I'm thinking about throwing a 10cm hahns hotside from a super16g i've got sitting around, onto a 20g built like that...if I ever go that route it will be extra work to run the exhaust and wastegate though, from where I'm at now..paid $125 for the entire super16g on ebay, in great shape, though, so you can have fun with being a cheapskate if you look around for deals.
*EDIT*
Or just get this
http://www.ebay.com/itm/GENUINE-MHI...Parts_Accessories&hash=item2a1d5020ef&vxp=mtr
or this
http://www.ebay.com/itm/TDO5H-16G-1...s=Make:Mitsubishi&hash=item43afd0abd8&vxp=mtr <<<someone needs to buy this, before I do just so I have an extra chra and exhaust housing I don't need, LOL
I'd look for a small 16g or big 16g, those are easier to find than an evo3 16g and still fairly reasonably priced. With 650's even a small 16g will just about max you out if you try.
^ Still have to get the 14B center housing machined.
If the OP's Big 16G center housing isn't ruined, he could easily do something like this with a 20G wheel and cover setup from Kamak/Kinugawa along with a new turbine and all of the internals.
True, add money for machining, and you would have a 20g for less than the EVO3 used to go for in the good old days...email the guy above me if your center housing is ruined, I've also got a couple extras sitting around.
Great thoughts all. So how do I know whether or not my center housing is ruined? Exactly what part is the center housing. Is it the area just around the compressor wheel?
I think that I want to stay with the B16g for now. Can't be arsed with injectors and a bigger fuel pump for now. My B16g setup ran rather untuned so I was never able to utilize it's potential.
Forester XT yep....04 so I've got the good Pistons/compression ratio/Final Drive but you've got the better tranny (if yours is an auto). Shiftpoints are rediculously high as far as RPMs go so a huge turbo as opposed to that T25 would work out alot better. Too bad the Auto TCU hasn't been cracked yet....kinda rediculous.
IMO, if you are looking for a B16g, try a S16g instead....underrated compared to its 16g siblings, and therefore much cheaper and easier to find...and it can still move something like 38lbs/min, while spooling faster than other 16g variants, with greater efficiency. I hate to sound like I'm regurgitating, but i've got a bit of a boner for the S16 and feel its been overshadowed by the big and evo3 16g's.
I had a s16g on one of my former DSMs and even though everyone raves about them, I preferred my b16g. Maybe the Galant's fat behind needs a b16g? ROFL
Quick question since it may or may not pertain to this situation (in regards to what the OP might use as a course of action): Are the Ebay compressor wheels anything worth having? I've seen some 16G/20G billet wheels, but wrote them off as offbrand crap.
Is there a link someone can provide that shows the machining process for a 14b/16g to upgrade to a larger wheel?
Last, are the Kinugawa/Kamak parts quality? I've seen them also, but didn't know if they're worth it.
Mitsubishi doesn't make billet 16G/20G wheels....so guess what? Every one you see is "offbrand crap". :D
I got a 5spd with a sti block (tbelt went @ 75k) it's my family rally wagon so much fun.
Anyways back to the topic
You are scaring me....89k miles here and still on the stock t belts. Don't plan to change them until it's time.
Nice ride.
Anyways...looking at the serial number on the turbo it seems like I am running a small 16g. Wondering if that could have caused the boost fade problems I was having at higher rpms and could never fix.
I have a while to pull the turbo it's not my daily.
Yes, back to the topic, would appreciate if someone would tell me how I can tell whether or not the center of the turbo is good or is this some game changer if I am running an S16g.
I personally recommend getting your 16G rebuilt by Turbo Lab of America and instead of a B16G wheel or Evo 3 16G wheel.. an Evo X 16G wheel.
The Evo X wheel has the same size inducer as the Small 16G, and the same size exducer as an Evo 3 16G. So in other words it would flow similar to an Evo3 16G, while spooling similar to a small 16G.
Very efficient wheel design.
Evo X compressors are standard-rotation. The Evo VIII and IX compressors are reverse-rotation.
The Evo X 152G6 has an inducer that is slightly bigger than a Small 16G but the same 68mm exducer found on all Big 16G/18G/20G turbos. It would be expected to perform in between a Small 16G and Evo III 16G, so around 39-40lb/min of peak airflow.
