Bigger Brakes
16vdohcturboawd
447
Apr 15, 2003
the moon, Maine
Hi i have a 92 laser rs awd and i want to know if the bigger calipers from a 93 would fit on my 92 with the single piston calipers without any modifications?
ps both front and rear
thank you.
Mines A 92 But The Build Date Is 9/91 So Will The Rear Calipers Fit From Other Years?
You can make anything work with enough parts. Worst case you have to change the whole spindle. Go junk yard hunting, they already have the wheels off.
You'll need the calipers, mounting bracket and the rotors and the front's will bolt on.
mavisky said:
You'll need the calipers, mounting bracket and the rotors and the front's will bolt on.[/QUOTE
will the rears bolt right on to?
steve said:
You don't touch the rear brakes except to put new rotors and pads on as needed.
Steve
I do need to touch my rear calipers though, they need to be replaced, so i was wondering if the rears are all the same or not i think the one im taking them off of is a 93 but i figured i would upgrade the fronts to dual pistons while i was in the back, the fronts are actually fine i really only need the back ones.
Honestly I don't know 100%. I know they are similar a simple look should tell you.
16vdohcturboawd said:
I do need to touch my rear calipers though, they need to be replaced.
Sorry, that wasn't clear from your postings.
I double checked CAPS and like I remembered, the rear calipers on the AWD cars are the same from MY91 through MY94 so you can swap over the ones from the 93 to your car directly.
Steve
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
