Bigger Injectors?
Rsawd95dsm
1,180
11
Feb 21, 2008
Zeeland, Michigan
Just making sure before I buy bigger injectors I have a question. If for now im just running a 16g and plan on someday soon getting a bigger turbo would it be ok for me to just get 1000cc injectors and be able to make the 16g run right for now? This way when i get a bigger turbo someday I would not have to worry about getting injectors again? Thanks for any input
Get 1000's there perfect injectors bigger will idle not that great on pump gas. I got my fic 1050cc can't wait to install them. But get 1000cc you won't regret it.
go with the 1000 if you plan on going bigger turbo in the future, if you get smaller ones and decide to go bigger turbo you'll regret it!
Keep in mind you need to have a tuning device to get those 1000c injectors to idle. DSMlink would be the best
Logging tuning software?
Goals? How big of a turbo?
I would say somewhere in the vicinity of 880 is enough for that 16g. I see members run 880's on fp 3052's. So is your so call upgraded turbo gonna be bigger then the fp3052?
Keep in mind if you ever plan on switching to E85 on something 20g size or larger you'll run out of injector pretty quick in the 1000cc range. Just something to think about if you ever consider switching to E85, FWIW.
Since you already have a DSMlink i would just go 1200+. you can tune to idle like stock. And also more room if you do decide to run E85.
fic 1150 if you want low impedence injectors, the differance between 1000cc and 1150 is not much so just get the biggest and not have to worry about it again and not to mention the fic 1050's and 1150's have a better spray pattern.
if you decide to go high impedence the rci 1200's are a decent value
