1G BEFORE I SEND MY ECU BACK...
Anthony Boni
5+ Year Contributor
212
23
May 13, 2018
Wrightstown, New Jersey
So long story short, I’ve been chasing an ISC issue in my car for several months on and off. I remove the ISC from the car and turn on my power, the ISC just vibrates. This goes for all 3 of the ISC motors I’ve tried. With the car running, the ISC motor starts at 120, slowly descends to 0, then slowly ascends back to 120. It repeats this the entire time the car is running. I’ve also left one ISC motor installed, and plugged in another ISC and sat it on top of my valve cover. Link showed the ISC position changing, but nothing was happening to the ISC motor sitting on the valve cover. It was just vibrating ever so slightly. Unplugging the ISC with the car running makes no difference in the way it idles.
It’s a 1990 DSM with a 91+ TB. I’ve swapped the two wires required when running the newer throttle body and ISC. I’ve sent my ECU to ECMTuning and they fixed a few things and sent it back. I’ve replaced the ISC motor 3 times. I’ve checked for resistance in the wires from the ECU to the ISC plug. I’ve checked I was getting 12 volts to the two power wires at the ISC plug from the MPI relay. I’ve ohmed out every one of my ISC motors. All of this, and I’ve found nothing wrong.
The only thing I can think of that can possibly be wrong is my ECU! It’s not my ISC(s) and it’s not my wiring. I trust the guys down at ECMTuning, but I’m hoping they overlooked something because I am losing my freaking mind trying to figure this out.
Some other things I’ve done before I’m asked: Compression tested the engine, leak down tested, boost leak tested, smoked the intake manifold, all new timing components, Verified base timing. Everything else on this car is PERFECT. I just can’t figure out this ISC problem!
I’m running speed density with an Omni 4 bar straight off the intake manifold (no Ts) as well as a GM IAT sensor.
What else could there be? Please help me!
Yes, if the circuit has been isolated (I don’t have a diagram to work with here), that’s how you’d do it.
So in this case —> If it means disconnecting it at the two ends (ecu, isc), then yes that is correct.
And if you have anything less than ~10k ohms. I’d be questioning something.
When I went to school for automotive electricity, electronics, etc. Ford’s spec was anything greater than 10,000 ohms is considered an open. So I usually use that as reference.
Awesome I'll do that real quick! Worst case scenario, the car idles and runs great with the ISC unplugged and the FIAV deleted. I know a lot of guys with S90 throttle bodies that don't run an ISC motor. Wonder if there is a way to "simulate" ISC position. I feel like I've read something about it somewhere. Could have been my imagination LOL
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
