Resolved BCS Restrictor Location
b00stin92
Mar 20, 2011
Brown Deer, Wisconsin
Sorry guys, I have looked everywhere, where is the location of the BCS restrictor. I know exactly what it looks like, is it under my air filter? I seemed to have searched everywhere underneath there and do not see it! Would appreciate the help!
Thanks
Here is the location of the BCS: http://members.shaw.ca/dsm.1000q/Engineprimer/1G/bcs.htm.
For the restrictor: Tech Guide: 1G 4G63t Upgrades: Stage 0 Power - DSMtuners
1G 4G63t Upgrades said:
Step 11: Remove the BCS Restrictor
If you do not have a manual boost controller, you can safely up the boost about 1-2 psi by removing the restrictor in the boost control solenoid. In the nipple that is perpendicular to the body of the solenoid, you can insert a screw or a drill bit, and then pull out the restrictor. Make SURE not to drill into the body!!!
Also:
http://www.dsmtuners.com/forums/newbie-forum/7696-bcs-mod-restrictor-removal-merged-2.html#post1462333 -- shows the port described above, for those visual folks
BCS Restrictor Removal -- although it is written for a 2G (the method is the same, you're only dealing with a different looking solenoid in a different location), you can clearly see the difference in port size on the BCS as well as what exactly you are aiming to pull from the solenoid
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
