mbc help bcs?
Garrett95tsi
Jan 28, 2010
quakertown, Pennsylvania
ok this is how my mbc is installed but what about the Turbocharger Waste Gate Solenoid Valve [Boost Control Solenoid (BCS)] that came stock its just unpluged shouldent the two rubber hoses from that be hooked up also i need help any pictures of how it came stock or installed with mbc would help i cant reamber were the hoses go thanks
If you are running a MBC, then just follow the diagram you posted as that's how it's to be hooked up. The BCS is just an electronic boost controller used by the ECU. Using an aftermarket BC you bypass the BCS.
Edit for below:
Keep the solenoid plugged into the wire connector. The hoses can be taken off and it does not need to be capped off either.
Make sure you cap the line coming off right behind the air filter though. But yea, you picture in your first post is correct.
