silentscreamer
- 106
- 1
- Oct 11, 2008
Moncton,
NB, Canada
i purchase a set of evo 8 spring a while back at a good price and then purchased a set of brian crower 280 cams.
after looking at the specs of the cam @ 0.422" of lift with a 0.040 shim and an installed hieght of 1.56 that would leave me with 1.098" spring height at full lift. from what i have found out thru the forums the safe height is 1.095" and the coil bind occurs at 1.035".
now with all that being said this is going to be used on a 2.3L so a max rpm of 7500 is going to be set. would it be wise to run these springs untill i can get the cash for a set of manleys?
any help would be great. thanks
