420A Battery relocation
Brandoomfl
Apr 16, 2015
Merritt island, Florida
**1996 eagle talon with a 420a motor**I was doing a battery relocation to my trunk. I completed it and drove fine for about 30 minutes, when I was slowing down and it just cut out on me. Pulled it over tried starting it up And only getting the started to crank, won't fire up. Checked fuses and my 30amp fuse is blown. I replaced it and blew it right away. Decided to just move battery back to oem location and it's still blowing the same fuse and only cranking not firing up.
Yeah I would second verify your grounds again including the one coming off the battery to the body. What gauge wire did you use for the relocation and did you have a good solid body ground from the battery.
I double checked all ground wires, the one leading to my body and the one that leads to my motor. The fuse is a 30amp fuse labeled motor. I used 4gauge I was told to use a positive cable from a jumper cable. So I bought a 20ft and used that.
Ran it through my ac vent through my center peice under my seat and into my trunk. I traced all my negatives and there is nothing I could notice. Am I able to upload videos on here to show what I'm working with?
