2G Battery cable
Steven A Schiltz
5+ Year Contributor
39
Apr 13, 2019
Memphis, Tennessee
So here my question do the battery cables that go from the battery to the starter and from the battery to the starter do they have inline fuse links?
Or just straight is so was amp are they. First fsm and the previous owner decided to do his own wiring
Battery to the alternator I ment, I see I put the same this twice
I swear the oem wiring for the alternator is fusible link wiring so that the internal metal wire (it's a pair of white insulated wires) will melt/fail in overload conditions. I have this vague recollection of discovering that in my research when I was designing my alternator/battery rewire.
If you're wondering if you should put a fuse of some kind between the alternator and everything else you absolutely should.
Stock wiring already has a fusible link for the alternator. Its even labeled as such and its bolt in.
Well the previous owner did a battery relocation with amp wire and there no protection in the wires and I want to add the protection so I was just trying to find what fuses to use. This car is no where near the stock wiring haha been going behind him for almost a year because I keep finding more and more wiring problems (face palm) the guy did it as a cheap build and I know and what I'm figuring out you need some know how to maintain and repair these cars and kinda need some know how to do so. So this website has really help.
