Anfurnyy
Supporting Member
- 1,514
- 1,962
- Jul 4, 2020
Rapid City,
South Dakota
Those of you who have cleaned the inside of your block while its out. What was your process and how successful was it?
I pulled my motor to build it and its really dirty, plus i did some grinding for the Kiggly Girdle install, and ive done the porting/smoothing of the front oil passages on the front. Im worried that these shavings have gotten in the oil Gallery and might hurt the motor later on. I DO plan on bringing the Head and the block in for a hot tank and cleaning but i wanted to personally clean and remove as much contaminates from everywhere as possible.
What process have others used? I have degreaser, and a pressure washer, brake cleaner, ATF and i have all the freeze plugs removed, and an air compressor with an air gun. What have you used to keep the block from surface rusting after pressure washing it?
or should i leave it completely up to the the shop do clean?
I have searched and seen a few posts from Bogus about a final cleaning after the shop. I've also watched jafros video about block prep but I wasnt sure if that might be enough to do a deep clean of the gallery or not.
