Intake Tb cleaning
Try and keep the TB open with one hand and spray it down with cleaner and wipe all the grim/black away with a nice clean rag
If the carbon buildup is bad enough, carb cleaner won't even scratch it. The only way to really clean it is to take the manifold off and have it hot-tanked. I did this last year to mine. At work we use some foaming throttle plate cleaner that just eats carbon buildup (I've used it to degrease engines) and I let about three cans of that sit in the manifold for a couple hours, scrubbed as far in the plenum and runners as far as I could with a wire brush, then sent it to the hot tank, then RE-foamed it and scrubbed it and there was still carbon in some of the nooks and crannies.
The throttle body, on the other hand, is a lot easier to clean. You don't even have to take it off to get both sides of the butterfly cleaned. Be careful, as there are some ports that you don't want to get chemicals into, and you don't want to mess up the throttle body shaft seals.
^Wow, look at all the carbon still in the ISC chamber and passage.
I am assuming your name is steve? LOL
But that is a pretty looking TB. I wish soem of my shit was that clean. I am in the process of cleaning it up, Anyone used the chemtool on it?
