spyderdrifter
- 5,434
- 864
- Jul 11, 2009
Somewhere in,
Colorado
This past Monday, Labor Day, I was returning home from work and stopped to grab lunch. While I was in the drive through line, I happened to turn my wheels and heard a weird clunking/ binding, metal on metal sound coming from the driver side front wheel. This was while stationary. It persisted while driving slowly as well, and turning wheels to replicate the sound. So I carefully rushed home and got the front up on jacks, and haven't driven it since.
I did some searches and came across the recall info for the lower lateral control arm ball joints. So I contacted the Mitsubishi dealership here in town, and they suck at returning calls, and found out that this recall was performed on one side, but they couldn't tell me which one got replaced. They said it wasn't showing on the computer. I call BS. So I said screw it, and ordered a new control arm w/ball joint from JNZTuning. Still waiting for it.
I have looked over the components on the car and the ball joints look ok, despite being able to push in on the rubber. Shouldn't they be firm, like having grease inside? Also I discovered my driver side outer tie rod bushing is basically split in half along the seem that used to be there. Its split around half the circumference of the bushing with obviously no grease inside. Would this tie rod bushing be more likely the reason for the noise than the ball joint? I don't want to end up replacing the control arm and having to pull everything apart to do the bushing and have no need to do the control arm. I'm aware that regardless of the control arm, I need to replace this bushing immediately so that needs not be said, I will be doing it. Just would like that to be the problem after all and not the control arm.
needs to be replaced due to corrosion and now the slightest bit of mushrooming I did to it.
