upper ball joint help
racingmason
71
Jan 11, 2011
Colorado Spring, Colorado
ok i got the tranny in and everything is done except it cant get the upper ball joint nuts to tighten with out spinning the stud. Bots shides, there is hardly any play in them at all. I have tried getting it to seat as far as i can in the steering knuckle, with pry bars etc, but i vant get it to be far enough down for the taper to hold it.
If its on jacks stands, then place a stand, block whatever under the lower control arm this way the knuckle doesn't move down when you pry on it. Have someone pry down on the upper control arm while you tighten.
Or you could put a wood block between the upper control arm and the fender well, and jack up the lower control arm very carefully.
Impact guns will make this easier.
If it's what I think your talking about I usually use a vise grip to hold it then tighten it as much as I can before I take it out. Right now mines are not all the way tucked in and I've been driving for hundreds of miles with no problem. but of course that's not the peace of mind I was looking for. I check it here and there and all seems fine.
WTF Did you just suggest that its ok to leave a ball joint loose? WTF
will try the jack stand, i tried jacking the lca but it lifted the car
put pressure on it, and use an impact
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
