Resolved Balance shaft delete bearing
StrokedYamama
Aug 9, 2021
Portland, Oregon
Does this have to be fully open or closed or is that correct fitment
Solution
That looks like it's to the outside of the block, isn't it? If that's where you have it, it's absolutely fine. The port you want to block is going towards the main oil gallery. See this thread as a reference: Blocking off oil galley
Referring to that thread, the 1/8 NPT plug is to the outside of the block. The 1/16 NPT plug is going to the main oil gallery. That's what needs to be covered. And these bearings only have the one hole in them so if you have it towards the outside, it's a-okay.
Solution
Are you doing a balance shaft delete? or installing new bearing and trying to line the hole up?
Yes it is the first one that's on the oil pump side of the block . Thank you for the information
Looks like Brian had the answer. That hole doesn't do anything.
Okay sweet thank you
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
