balance shaft bearing advice?
you will need to take them out and turn them so they block off the holes on the block,dont know where you got ## kit from but when i got mine from jacksons it came with new bearings so i just pop the old ones out then put the new ones in making sure i turned them to block off the holes be sure to do it right or you will have no oil pressure
