Bad wheel Vibration at 40-55 MPH Inner tie rod? or Wheel bearing?
BJ350hp
Apr 27, 2008
Gainesville, Florida
So I searched and have read about the many things that could be causing my bad wheel vibration. I think iv got it nailed down to inner tie rod or wheel bearing.
My car is a 97 GST Spyder.
So far I have replaced: Tie rod ends, New CV axles, Upper Ball joints, and had my alignment done with new tires mounted and balanced.
Today I did like most post say and checked the front wheels for play. I got no play up/down and left/right from the front passenger wheel. But on the drive side I get play left and right but not up/down. So I think it's got to be my inner tie rod or the wheel bearing.
Any ideas would really help me out.
Also made a video to help.
YouTube - Vibration
(Edit: when I first tested the wheels it was with all 5 lugs bolted down!. I bolted the wheel back on with two just to make the quick video)
UPDATE: Post # 12
:hmm:
I've replaced the front wheel bearings in my car, I didn't feel any more or less vibration before or after doing so. When the wheel bearing goes bad, you have up/down, left/right play and you can normally hear it grinding away, even over the sound of a catless 3" exhaust. The second poster (OP found his problem) is in process of replacing trashed motor mounts which would be causing more vibration to enter the cabin and I'm waiting (along with others) to see if that eliminates the problem before going into more 'diagnosis' mode.
I have the same issue as op. It appears my driver side caliper piston is froze.
I do need a inner tie rod too, I'm 100% it's the caliper causing my issue though.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
