Resolved AWD Half Shaft Carrier Bracket Part Number
EvolvingGST
1,710
6
Jun 24, 2002
Boston, Massachusetts
Hi Guys I am trying to get back in the game.
I bought a shell without a axle carrier bracket. I was wondering if anyone knew what the part number was so I can see if I can source one.
Thank you,
Jason
Everything you need is in the following thread:
http://www.dsmtuners.com/threads/halfshaft-bracket-year-differences-ac-mount.298124/
In addition, you may have trouble sourcing the bracket on its own new. The bearings/seals however, are available. Also be sure to source the correct bolts for the bracket shown in the following link:
http://www.jnztuning.com/product_info.php?name=Axle Carrier Bracket Bolt Kit&products_id=3566
Not sure if you plan to retain A/C or not. If you decide against it, you can cut up the A/C bracket to use as the spacer, or order an OEM spacer like this:
http://www.jnztuning.com/product_info.php?name=Axle Bracket Spacer (A/C delete)-DSM&products_id=3568
    • Sdcryan1
