ARP Head Studs
jconcepcion4g63
94
Sep 13, 2012
Tiffin, Ohio
Will the ARP Pro Series 8740 alloy studs be enough for my build or will I be needing the L19 series studs??
In a nut shell my build will be stock block and head with top mount undecided hx 40 or also leaning to maybe a Precision not sure yet + race gas and 25-30psi boost. Oh yea using oem head gasket not MLS.
It sounds like you would probably benifit from l19's, soon that 25-30 will turn into 35-40 LOL..
Then again with the stock block your going to be pusing the limits. I'm planning on something very similar but using a t3 52trim and pushing a fresh rebuilt block around 400hp. I'm using the regular arp's so if you have no choice but to stay below 25-30 then you will probably be fine.
If it is a 6 bolt the standard 8740s will be fine. If it is a 7 bolt it would be worth it to do the 1/2 head stud conversion or L19s
