arp head studs
I assume you have ## head off?
Anyways finger tighten the studs into the block. Make sure the allen wrench side is sticking up. No oil or lube on the block side. Install NEW head gasket. Install head and use the lube supplied with the studs on the thread side sticking up. (if none was supplied then use moly lube from an auto parts store). install washers and torque the nuts each to 30ft/lbs (use torque wrench, VERY important) in the correct order (See pic). Then 60ft/lb, the 80lb.
I have 58 and some change on it. Should I still change the HG. I have to do the timing belt too soon..
ooooooooooooooooooo thats great they just erased my avatar........Had it for two years then bam......
put two nuts on and tighten them together. Then undo the stud by turning the bottom nut..
IMO...spend the extra time and money and do the head gasket and timing belt now. You won't regret it later, trust me.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
