turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Here's something i've pondered for years and have enver found a definitive answer (even from ARP )
With the ARP lube you are supposed to torque them to 80ft/lbs, but with motor oil you're told to go to 120 ft/lbs.
So, if you've assembled the motor and torqued the head with ARP lube, then put a few thousand miles on and want to re-torque the head, What torque spec do you use?
I ask because in theory there should be some ARP lube still on those threads, BUT, what about the oil from the engine that gets spalshed on the studs and makes it's way down the threads and what effect does it have on the value you should re-torque to?
TO be honest... I have always just done the 80 on first assembly, then when re-checking them after the engine has ran I use the 120 based on my thoughts of the engine oil washing away the ARP lube after some time. Now, I've never had them turn any more than MAYBE an extra ~2 degrees on the 2nd torque when using the 120ft/lb motor oil spec if it's been more than a few days since orignial torquing. But with this new built motor and my now very thin wallet, I don't want to take any chances and would like some input from others as to what spec you used and were there any negative results with either one?
It's not that i don't know what i'm doing, but this is something i've NEVER found a clear answer to. ARP can only suggest to completely clean the threads, apply either lube and torque correctly, but that eliminates the purpose behind "re-torquing" in the first place IMO. (but I have also thought of maybe doing it that way one bolt at a time, but still am unsure) If nothing else i'll just go 120 like i've always done and call it good.
The last time i re-torqued them was back in December '08, and i just checked them at 80 ft/lbs since there was only a few short cycles on the engine and i felt there was still ample moly in the threads. But by now I'm pretty sure the moly lube is probably diluted and washed away almost completely at this point.
There's just something so cool about being able to roll on the gas at 60 in third and hear both tires scream and squeel as the tach heads for redline (like it use to do in 2nd)...and so everytime i pass some one on the interstate now i have to do it burning rubber, or at least let them start to sqeel then shift
.... but now i got POSI BABY!!! and when i couple that with some fresh M&H slicks it should be a really intense ride then (for a FWD street car anyway) I know there's plenty of cars on here that are a lot faster, but mine is still a blast for me!
