2G ARGHHHH!!!! Stripped my ARP bottom end bolt!!! Any advice on how to get it out???
Twizted99GSX
143
7
Oct 12, 2014
Champaign, Illinois
I was told that the bolt was 7/16 deep socket. I used on bolt and got all the nuts off and on last nut it stripped. Now i did notice when taken it off they were not TIGHT they kinda wobbled. So last bolt wont grab now i cant get my girdle off i cant even use hex key to get it out. Any suggestion?? Was that proper socket? 13mm? The connecting rod bolts were 1/2 sae. And the 7/16 worked but i know wasnt tight tight. Like the 1/2 felt. Here are pics of bolt. I used heat and PB even tried taking whole bolt out. Wont come. I even tried tightening down other bolts to relieve pressure. Nothing. HELP DSM'ers!!
what boostdawd said.
I've done this probably a thousand times.
Do the math and find the next size down in mm or inches. Whatever comes first, THAT'S what you use.
I would refrain from using a torch right here. I think that's unnecessary in this situation.
IF ALL ELSE FAILS.... And you can't get that next socket size down on (which I doubt). You CAN file down the next size down wrench and eventually get it to fit with some hammering IF you have the room to use it.
Like I said, been there, done this at LEAST a thousand times.
I refuse to to be put in those type of situations and take an L....
MR IRWIN WAS THE MAN!!! got that bolt out in seconds YERRRRRRPP!!... I took everything apart and got the crank out and the pistons. I cleaned it up and oiled it a bit cause I was on time crunch today with stuff todo but got Crank, Girdle, Block, and Each Individual Piston wrapped in Plastic Wrap. Will post pics when I return.. Thanks again My DSM Family!!!
Be Blessed...
