Anyone use this gasket set before?
I've replaced a full gasket set while rebuilding the engine, but certain no from eBay. Personally, I would not get cheap product from eBay. Think about it, it one gasket gets blown you'd have to go digging around your engine to get to it and replace. But I don't know what level of mods your over.
you dont want to go cheap on the gasket they are very important especially in a car that sees boost. extremepsi.com sells a full FELPRO gasket kit that is much better.
Look at the intake gasket....Looks like its for a 2g......Maybe the pic aint accurate... I wouldnt buy it...
Got extremepsi... Best gasket kit by far!!!!!
It came with turbo gaskets for all 3-turbos... Auto turbo 5cm gasket- 5-speed 6cm gasket, and a 7cm turbo gasket. oem intake gasket-metal. 2 o2 gaskets. 1 for 1g housing, 1 for evo 3 housing... These gaskets arent cheap.... And theres multiple ones in there. Those turbo gaskets in the pic look like they are not even steel.
Extremepsi rocks...:rocks:
my .o2
Fel-pro is excellent for an mild (400hp or less) build. I've run their head gaskets to 30psi for thousands of miles w/ a set of arp head studs.
I run a felpro hg as well. Oringd, and arp'd.:)
Never a problem.
Metal ones i have had 1 problem with... And the time it takes to remove all the stuff again...I'll never go back to metal.
Never a problem.
O-ring-ing is headgasket cheating. . . Like water injection is tune cheating. . . I love it!!!
The felpro gasket an handle all the cylinder pressure 500 whp can bring w/ stock 6-bolt head bolts. It can handle a MILD string of knock w/ arp head studs.
