Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
I started doing some research for a document I was thinking of putting together, and surprisingly there isn't a lot of specific information that I can find. (maybe I'm just not looking in the right places...I dunno. I'm getting old).
What I'm looking for is max airflow information for various components, in lbs/min. (nice standard unit that everyone is used to). I'd like to come up with something that shows things such as "2.5 inch IC piping will flow x lbs/min.", for example. The goal here is to provide a reference that can be used to determine when components may start to become a restriction as airflow is increased.
For a lot of these, there may not be a practical upper limit, or at least not one that has been found. In that case, I'll just go with the highest number that has been supported with good results. So for example, if someone flowed 79 lbs/min while running the FP race exhaust mani, that's what we would use for it. Please note that I purposely left max airflow for turbos off this list...that discussion could (and has) gone on for years. This is just for related components of interest.
Before I get flamed, I understand that there is interaction and countless factors at work here. Please don't over complicate this; I'm just trying to get some ball park numbers to look at.
Anyway, if you have solid lbs/min numbers for any of the following, please post it up. We don't need opinion or hearsay...just numbers that you have seen (and logged), or a link to these numbers. Please feel free to add any components I missed that may be of interest (Please make them bold if you do).
Copy the list from the post immediately above yours and change any numbers that you have data for that are larger than previously recorded (that you can back up with a good log in case someone calls BS.
). I'll get it started with a typical airflow (38lbs/min) on my current 16g setup. The values are in red to make them easier to see, so just make any changes between the font tags. Once this has run for a while, I'll compile the data and post it up somewhere.
BTW - If this already exists somewhere, well...then nevermind.
EDIT:
Please do not post any numbers unless you are sure that airflow was fairly accurate and is repeatable. This isn't a contest; we're just trying to get a feel for how much airflow different components have supported.
). I'll get it started with a typical airflow (38lbs/min) on my current 16g setup. The values are in red to make them easier to see, so just make any changes between the font tags. Once this has run for a while, I'll compile the data and post it up somewhere.BTW - If this already exists somewhere, well...then nevermind.
EDIT:
