Air temp at throttle body
1gengsx
33
Jul 18, 2010
Mechanicsville, Maryland
I'm looking for a way to monitor my intake temps at the throttle body on my 1g eclipse. I do not want the temp from the MAF sensor. I have the factory computer(chipped) in the car.
I don't mind running an after market gauge but I can't find many of them. Also it needs to have a threaded style sensor.
Any ideas would be great. Thanks.
Get a GM IAT for a thread in sensor. What gauges are you finding?
You could also just get DS-Map or ECMLink V3 and go with a speed density setup :)
I have found PLX and Cyberdyne. I have not heard of either of these companys. I would like to use the gm thread iat sensor. Do you know of a gauges that will read it? Or a program for the logger that will? I'm not worried about logging it I just wanna monitor it. I'd rather not change the engine managment system(Although I know that will help more than just with IAT readings) Can it be wired to the factory ecu to be veiwed under some unused reading?
