Aftermarket Front Transmission Mount ?
2G's have one brace that runs from the front subframe to the radiator support. The front roll stop (mount) bolts to this piece. There's not much weight to be saved with a chromoly replacement. There's not really much space to be saved either, so I doubt anyone has built one yet.
Are you having clearance issues with the mount itself? If so, one good idea would be to fabricate a small, solid replacement mount that replaces both pieces of the factoy mount. If I can find the time tonight, I'll poke around my engine bay and see if I can come up with a design for one.
I am not looking for a weight savings my problem is possible clearance issues i am putting a 90 silicone boot on and going to give that a try but the 90 is very close to the front engine mount and i am concerned that it could rub a hole in the boot
Picture?
