raptoranderson
- 195
- 23
- Sep 24, 2015
Graham,
North Carolina
So the infamous front-right engine mount bracket on my 2G Eclipse has shorn-off at the bolts and so I am in need of a new one. Does anyone have any suggestions on how I can fix this easily and without much hassle? It seems as though I'm going to have to remove the cam belt and jack the engine up so that I can get to the bracket as the engine has dropped 2 or 3 inches on the right-side because the bracket broke. I don't have a trolley jack so the car will undoubtedly have to go to a garage to have the work done, plus it needs to be remapped and tuned since it's running lean
but thank you for the offer! I have a spare of the mount itself and both of the rear mounts should you or anyone else need them
As well as a 16G turbocharger rebuild kit and O2 housing and a T25 with a bad thrust seal (hence why the previous owner replaced the T25 with a 20G)
it looks like the mount bracket can be removed without having to remove the timing belt or any of the gears the belt attaches to. Is this correct or am I going to have to remove other parts to get to it?
