transmission mount bracket
cedp
May 6, 2009
jerz, New Jersey
does anybody know where i could get the studs and nuts that secure the mount bracket to the transmission? i went to the dealer and they said there is no listing for them. i also went to a parts store and they dont have them either. i figured my only option is the junkyard but is there anywhere else that would have them? thanks i also have have 2g fwd
I'm a bit confused about your description of the location of the bolts your looking for, a picture would help TONS! If its what I THINK your talking about below is the info about the bolt that you'll need.
Take a trip to Home Depot and find a bolt with these characteristics...
shaft diameter x thread size : 12mm x 1.25mm
length : 30mm
thread length : 23mm
head size : 17mm
hardness : grade 7
Home Depot sells bolts that are grade 8 so don't worry about the quality (hardness) of the bolt. These bolts also have a lock washer on them so be sure to pick one up while your there.
Hopefully that answered your question or atleast gave you another option than taking a trip to the junkyard HOPING they had a dsm with the bolts you needed.
:dsm:
