2G AEM X series wideband datalogging
If evoscan provides a programmable input for logging then you should be able to log whatever you want. Most tuning systems allow you use an "unused" ecu pin to log these types of things. If the X Series wideband allows a programmable output then you should have no issue doing this. If evoscan doesn't allow this then I'd look into a more feature rich solution.
