ECMlink Adjust Your TPS!
I ended up disabling TPS Adjust and left it untouched at my previous manual adjustment which had it at 0.63 at car off and 0.65 at car idling.
The IPS is now switching properly after the TPS goes over 2% throttle, although my maximum throttle is now back at 97% but I reckon the difference is arbitrary.
Thanks @steve ! Sometimes we just gotta listen to what you wisemen preach and go with it :thumb:
If it doesn't (it should) then maybe screw in the IPS a tiny bit so it doesn't activate the IPS inadvertently and redo your tps adjust. Ideally you would always set the TPS manually per FSM.
2G Throttle Body. The 2G IPS is inside the TPS, remember? Don't touch the idle stop adjustment on the TB if you can help it.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
