Adding a fuel injector
dsmgst1996
279
3
Feb 18, 2013
wellsville, Missouri
Does anyone use this anymore I used it once one a saturn sc2 that i put a t25 turbo on it work great on and off boost or is this just out of date?
Part I: the fuel hardware
The first thing you'll need to do is make a custom brass tee to send some fuel over to the injector. I went to a local hardware store and bought a tee with three 1/4" threaded fittings, plus two 5/16" barbs and one 3/16" barb. I put some teflon tape on the threads and screwed it together nice and tight. (Be sure to put the right barbs in the right place!) Once together it is installed in the fuel hose which feeds your fuel rail--it's the hose that is 5/16" in size. Be sure to use clamps which are in good condition; we don't want any leaks.
Now we install the injector itself. This is simply a run-of-the-mill cold start injector out of a junkyard Saab; it differs from normal injectors in that it doesn't pulse--it's either flowing constantly (on) or not at all (off). This is the style of injector you must use. Normal "pulsing" injectors will not supply a constant fuel flow and the resulting sporadic fuel delivery will cause detonation and destroy your engine.
In your metal intercooler pipe, drill a hole which is barely larger than the injector's nozzle--six inches in front of the throttle body is ideal. Temporarily put the injector in place, use its flange to mark where the screw holes go, then remove the injector and drill those holes. Once the holes are ready and the pipe has been thoroughly cleaned of metal shavings, place a half-inch piece of 5/16" fuel hose over the tip of the injector and install it permanently--the small piece of hose will compress and conform to the shape of the pipe making an airtight seal. Sheet metal screws will do the job perfectly; I even went so far as to add a very small dab of RTV for these screws to ensure a good seal but this is overkill so long as you don't drill holes which are too big for the screws. Now that the injector is mounted, plumb in the fuel hose from the 3/16" barb of the brass tee.
Part II: the pneumatic hardware
You need to mount a pressure switch to control the injector. (Go to NAPA and ask for NAPA part# 7011577. This corresponds to a hobbs pressure switch #76052 which is a single circut 5000 series normally open 2 terminal switch. It is factory set to 15 psi but adjustable 14-24 psi. NOTE: the switch pictured above is not the NAPA switch--it's what I had lying around. The NAPA switch is pictured below.) I decided to tee into the line for the fuel pressure regulator; I felt this was safe since there will be no bleed-off of pressure. Feel free to mount your switch wherever you like.
NAPA part number 7011577:
Speaking of pneumatics, you don't install an extra injector unless you're going to run more than 14 psi of boost. And if you're going over 14 pounds then you'll also need to trick the MAP sensor. My solution was to install a cutout raiser (though you could just as effectively install a diode--read about both methods here). I did make one deviation, though: rather than epoxy a plastic tee onto the valve, I bought a brass barb which screws onto the valve. This way I'd have no chance of messing up the machined seat for the brass ball inside the valve. See the difference below--Gus shows his way on the left while my method is on the right.
Part III: wiring it all in
Now all you need to do is wire everything together. The injector has two wires and polarity does not matter--feed 12v to one and ground to the other and you'll get fuel. I attached one wire to a constant 12v source; this line contains a 1-amp inline fuse for safety. I then connected the other injector wire to one of the terminals of the pressure switch. The switch's second terminal is connected to ground. When the threshold pressure is reached the switch closes and sends ground to the injector, turning it on. Once pressure falls below the threshold, the switch opens and the injector shuts off.
For neatness sake, I used as much of the injector's wiring as I could. When you remove a cold start injector from a junkyard car try to cut off as much of the harness as you can--you'll appreciate it later.
Part IV: dialing it all in!
Now all that's left is making it all work. Gradually raise your boost level one pound at a time; make sure your fuel gauge says all is well. If you hit overboost cutout, adjust your raiser very slightly (half a turn at a time) and try again. After a bit of experimentation you should get dialed in to your target boost setup. Once you do, be sure to read your spark plugs to confirm everything is okay. If it is, you're all set!
THIS INFORMATION IS GIVEN "AS IS" AND WITHOUT ANY WARRANTIES WHETHER EXPRESSED OR IMPLIED. NO WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE IS OFFERED. BY USING THIS INFORMATION YOU RELEASE THE AUTHOR FROM ANY LIABILITY WHATSOEVER.
Completely unnecessary on these cars what with the wealth of available parts... work-arounds such as this are long gone on this platform.
