Icebrew
- 17
- Dec 2, 2024
pageland,
South Carolina
What's up. This will be my 1st non-build thread post here. Here's the situation:
When I was pressing the inner balance shaft bearing out, with my socket got stuck in the hole. It's completely flush as you can see here.
It's a very tight fit, and I've even put an impact on it to try to twist it out, to no avail. Now here's the question, should I just leave it in there? I mean, it's doing the exact same thing as a rotated/blank bearing right? It should block oil flow just fine, correct? I'm sure I can get it out eventually, but I'm gonna be honest it would be really funny knowing that a 31mm socket is in the engine of my rally car, and it's a performance mod at that.
So, thoughts? Leave it or not? I have a Nippon BSD kit, so I have the blank bearings.
