a little advice before reinstalling head?
Nic_EclipseRs09
May 12, 2009
Santa Ana, California
I blew my head gasket so i took my head off and its in the shop getting checked for cracks and surfaced. I am getting a complete upper gasket set but i was wondering what else i should do while i have it taken apart. Im getting new timing belt, tensioners, water pump, radiator and thermostat. Are there any more parts i should replace while im at it? its a 98 420a n/t with 130k.
Thanks!
Bogus has also got a nice oil port mod for you.Ask him about it and he will tell you what has to be done.
well i have a 420a n/t not a 4g63t.
is it the same idea though?
and as far as the type of gasket i'm using i'm not sure i haven't bought it yet i was just gonna buy the stock gasket. I don't know the difference between them.
as far as surfacing goes..4G63, 420a, Ford, ANY head should not be Belt surfaced!
a MLS Head gasket is just what the name applys.. Muti Layered Steel
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Cometic Head Gasket (1.3mm): Mitsubishi Eclipse 90-99
A composite is a One piece deal, most have a perferated core with a facing on either side, and are much more "forgiving" to surface irregularites...
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Fel-Pro PermaTorque MLS Head Gasket: Mitsubishi Eclipse 90-99
oh ok yea i talked to the guy doing my head to make sure he was milling it and not belt surfacing.
Thanks for the information! i love learning all this stuff.
so my final list of things to replace while Ive already got head taken off
-timing belt
-tensioners(timing and idler)
-water pump
-oil pump
-complete upper gasket set
-radiator
-thermostat
and im gonna shop around and decide if i want to spend the money buy possibly a new light weight udp
sound good?
cam gears if its in your budget.... they will help bring the cams back into "true time" with the crank...
are you going to do the oil port mod?
