Talyn
- 441
- 19
- Jun 10, 2012
Pittsburgh,
Pennsylvania
So I've never quite been happy with any of the usual methods of dealing with unused vacuum nipples.
Looping vacuum lines, or plugging vacuum lines with bolts add's clutter, looks crappy, and while unlikely can pop off, will eventually dry rot, if the bolt is too big might make it break prematurely. Then there are those vacuum nipple plugs you can buy at the parts stores that somehow dry rot to pieces in only a few months if not weeks. There's crushing the lines (what a previous owner did to my current DSM) which probably doesn't seal completely. And lastly JB weld or similar, which again looks like crap, and can fail. Also these last two methods are irreversible should you change your setup and need a vacuum source again.
So when I recently saw a vacuum distribution block on a parts site I had the idea to basically copy those.
I am going to attempt to remove the unused throttle body nipples, as well as the unused PCV nipple on the IM and then drill and tap those holes for NPT fittings, which are commonly available as nipple fittings or plugs, and commonly used when people need to tap a boost or vacuum line. I have an old throttle body lying around that I will test this on first, but if it turns out well, which I think it will, I would like to make this a sticky for other people looking for a better solution like I was. I wanted to do it this weekend, but unfortunately nobody seems to stock 1/8 NPT pipe taps, and I am pretty sure that is the ideal size for the TB nipples. I did order one, found one for $4 and change on ebay w/ free shipping, I'll be attempting this next weekend and come back with my results.
